NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
LabVIEW 2017 visa read and write performance issue
When I am using the VISA in 8(VISA out 😎 function to read and writ a byte value to the resource. the it sill take about 0.005ms(milisecond) ,which is much slower than expected. I can reach 0.0015ms(milisecond) per operation(read or write) by using other drivers like give io access. why the VISA in 8 or out is much slower than others?how to speed up the access to the PXI driver.
Attached is one of my VI.
0 项奖励
1 条消息(共 3 条)
2,726 次查看
Hi,how did you get the time of 0.005ms,and what the resource did you use?
0 项奖励
2 条消息(共 3 条)
2,664 次查看
I use a PC and a PCI to CPCI adapter,and i also get the simular result by using a PXI system from NI.
0 项奖励
3 条消息(共 3 条)
2,574 次查看
