NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Multisim 10.1(10.1.357) crashed on some ms10 file.
I have post msg on:
http://forums.ni.com/ni/board/message?board.id=370&message.id=6349
but seems no response.
I'd like to post through "Contact NI"
Here are two ms10 files.
IR_38f-0.ms10
IR_38f-1.ms10
"IR_38f-1.ms10" crashes while "IR_38f-0.ms10" is ok.
I can open "IR_38f-1.ms10" by double-click this file,
but when I edit anything on it, it crashes.
it will crash by "open ..." menu instead of double-click.
but the file "IR_38f-0.ms10" is fine.
The only difference is that "IR_38f-0.ms10" has a U11A (a NOT gate)
 on the right-bottom corner. I deleted this gate and save it as
 "IR_38f-1.ms10", but the file seems damaged.
I have test it for several times, the result is always the same.
In fact, it seems that the new file will crash if I delete anything in file
"IR_38f-0.ms10" and "save as" it.
Wierd? It makes me crazy! Please help me!
0 项奖励
1 条消息(共 2 条)
3,522 次查看
Maybe your file is already crush. Have you try to rewrite the file with one gate component unplaced?
District Sales Manager | Shanghai Pudong, China
0 项奖励
2 条消息(共 2 条)
3,502 次查看
