The output voltage can be set at "measurement & auotmation(MS)" for the AIO voltage, it can be set between 0 to 10v, or the other -5v to +5v, go to the "MS" set the corresponding channel's output voltage to what you need.
________________________________________________________
Try to make everything Automatic
