NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
PCI6024E的最大采样频率到底是多少,200KHZ还是1.25MHZ??
What is the actual capability of sampling rate of PCI6024E,200K Hz or
1.25M Hz?
And how about PCI6024 and PCI6221?
If I set 5120Hz as the nominal sampling rate for a sampling of 2 channels
, what
is the actual sampling rate using PCI6024E? And how about 7680Hz?
0 项奖励
1 条消息(共 3 条)
3,777 次查看
The maximum sampling rate for PCI6024 is 200K. So even when you sample 2 channel signals, the sum of the A/D will be limited within 200KHZ.
 Suppose you assigned 5120Hz as the specific sampling rate for each of the channel, the cost for device 6024 would be double.
To find a good workbench--> -_- a good friend-_-..
0 项奖励
2 条消息(共 3 条)
3,768 次查看
The actual sampling rate using PCI6024E could be read from sample clock rate of DAQmx timing property
0 项奖励
3 条消息(共 3 条)
3,749 次查看
