The maximum sampling rate for PCI6024 is 200K. So even when you sample 2 channel signals, the sum of the A/D will be limited within 200KHZ.
Suppose you assigned 5120Hz as the specific sampling rate for each of the channel, the cost for device 6024 would be double.
