NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
TestStand下实现Socket有问题
代码如下:
服务器端:
// ShellAPI.cpp: implementation of the ShellAPI class.
#include "ShellAPI.h"
#import "teapi.dll"
#include <winsock.h>
#pragma comment(lib, "ws2_32.lib")
extern "C"
 void __declspec(dllexport) __stdcall SelfTest(TS::SequenceContext *seqContext, bool &result)
  WSADATA wsaData;
 int iResult ;
 SOCKET server;
 sockaddr_in service;
 SOCKET AcceptSocket;
 int bytesSent;
 int bytesRecv = SOCKET_ERROR;
 char sendbuf[32] = "Server: Sending Data.";
 char recvbuf[32] = "";
 char i;
   iResult = WSAStartup( MAKEWORD(2,2), &wsaData );
  if ( iResult != NO_ERROR )
   result = false;
  // new socket
  server = socket( AF_INET, SOCK_STREAM, IPPROTO_TCP );
  if ( server == INVALID_SOCKET )
   result = false;
     BOOL bReuseaddr=TRUE;
  setsockopt(server,SOL_SOCKET ,SO_REUSEADDR,(const char*)&bReuseaddr,sizeof(BOOL));
  // bind socket
  service.sin_family = AF_INET;
  //service.sin_addr.s_addr = inet_addr( "172.20.0.30" );
  service.sin_addr.s_addr = inet_addr( "192.168.0.1" );
  service.sin_port = htons( 27015 );
  if ( bind( server, (SOCKADDR*) &service, sizeof(service) ) == SOCKET_ERROR )
   result = false;
  // listen socket
  if ( listen( server, 1 ) == SOCKET_ERROR )
   result = false;
  // accept link
  while (1)
   AcceptSocket = SOCKET_ERROR;
   while ( AcceptSocket == SOCKET_ERROR )
    AcceptSocket = accept( server, NULL, NULL );
   server = AcceptSocket;
   break;
for(i =1; i <= 100; i++)
  // send
  bytesSent = send( server, sendbuf, strlen(sendbuf), 0 );
  //receive
  bytesRecv = recv( server, recvbuf, 32, 0 );
  closesocket(server);
  WSACleanup();
  result = true;
客户端:
#include "stdafx.h"
int main(int argc, char* argv[])
 WSADATA wsaData;
 SOCKET client;
 sockaddr_in clientService;
 int bytesSent;
 char sendbuf[32] = "Client: Sending data.";
 bool bReuseaddr = true;
    int iResult;
 int i;
        printf("Error at WSAStartup()\n");
    // 建立socket socket.
    client = socket( AF_INET, SOCK_STREAM, IPPROTO_TCP );
    if ( client == INVALID_SOCKET ) {
        printf( "Error at socket(): %ld\n", WSAGetLastError() );
        return 0;
 setsockopt(client, SOL_SOCKET, SO_REUSEADDR, (const char*)&bReuseaddr, sizeof(bool));
    // 连接到服务器.
    clientService.sin_family = AF_INET;
 clientService.sin_addr.s_addr = inet_addr( "192.168.0.2" );
    clientService.sin_port = htons( 27015 );
    if ( connect( client, (SOCKADDR*) &clientService, sizeof(clientService) ) == SOCKET_ERROR) {
        printf( "Failed to connect.\n" );
        return 0;
for(i = 0; i < 1; i++)
    // 发送并接收数据.
    while( bytesRecv == SOCKET_ERROR ) {
        bytesRecv = recv( client, recvbuf, 32, 0 );
        if ( bytesRecv == 0 || bytesRecv == WSAECONNRESET ) {
            printf( "Connection Closed.\n");
            break;
        if (bytesRecv < 0)
            return 0;
        printf( "Bytes Recv: %ld\n", bytesRecv );
 bytesSent = send( client, sendbuf, strlen(sendbuf), 0 );
 printf( "Bytes Sent: %ld\n", bytesSent );
 closesocket(client);
 Sleep(50);
 WSACleanup();
 Sleep(50);
 return 0;
以上代码在VC6环境下编译通信均正常,但把服务器端编译成dll整合到teststand序列中只能执行两次,第三次客户端connect函数能成功,
但服务器端accept函数收不到东西,阻塞在那。不知何故,盼复
0 项奖励
1 条消息(共 2 条)
4,240 次查看
大家讨论一下如何,没人了解吗?
0 项奖励
2 条消息(共 2 条)
4,200 次查看
