修改时间 08-03-2010 10:43 AM
using ibrd reading curve data in SONY/TEK_370A test instrument, but the result is not correct.
in ibrd function, the buffer is defined as string type, but the curve data is hexadecimal . can IBRD function read hexadecimal using string type buffer.
