NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
how can ibrd reading hexadecimal data
using ibrd reading curve data in SONY/TEK_370A test instrument, but the result is not correct.
in  ibrd function,  the buffer is defined as string type,  but the curve data is hexadecimal .  can IBRD function  read hexadecimal using  string type buffer.
0 项奖励
1 条消息(共 1 条)
2,858 次查看
