NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
how to open a cfg file
I am compiling using CVI, how to open a *.cfg file ? thanks
0 项奖励
1 条消息(共 5 条)
4,576 次查看
Can you explain more clearly what do you want to realize?
0 项奖励
2 条消息(共 5 条)
4,565 次查看
I am doing some update with a CVI program ,which compiled by others. In his program folder, I find a  *.cfg file, which is doing config the CVI, I try to open it with notepad...but can not display correctly. What do you think of it?
0 项奖励
3 条消息(共 5 条)
4,559 次查看
I am not sure if *.cfg file is configure file, try ultraedit to open it.
0 项奖励
4 条消息(共 5 条)
4,555 次查看
thanks, but it seems still not display the code correctly!
0 项奖励
5 条消息(共 5 条)
4,549 次查看
