NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
use labview R7831 input can get data but simulink can't get the data
  hello
i am work in hil with car safe project, i want to use labview simulink and carsim to do a hil test. i had use simulink interface toolkit,connect the simulink and labview, when i use a control module when i change the control value ,in simulink the value chang too,now i use the R7831 to get the analog data and use a  local valiable module to put it into control module,control module value can change but simulink the value can't change, someone can't help me ? give me some support ,example .thank you!
0 项奖励
1 条消息(共 1 条)
3,173 次查看
