NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
vision 图像的读取程序
这个就是程序的后面板,不知道哪里问题,运行前面板没图片,请高手指点!!!!
0 项奖励
1 条消息(共 4 条)
4,631 次查看
You would need to change the following
1.Use another IMAQ Create VI to create a separate image for the Resampled Image
2. Make sure that your front panel image has Snapshot Mode enabled
Andy Chang
0 项奖励
2 条消息(共 4 条)
4,624 次查看
谢谢,我重新修改了程序,图片显示了,但是没有找到“zoom to fit ”这一选项,所以有时候会出现下面这个情况:
前面板要么是原图显示空白,要么是重新采样空白.....运行时间一长就说图片不够大,这种情况是什么原因啊?还有那个zoom to fit 是因为我版本太低的原因吗?我用的才是Vision 7.0..........
0 项奖励
3 条消息(共 4 条)
4,599 次查看
Could you post the image that you are working with?
Zoom-to-fit option was a new feature implemented in NI Vision 8.6 so it does not seem like you would have that funtionality. Nevertheless, if you can post the image that you are using, I can try to see if the same error is observed in LabVIEW 2009.
Andy Chang
0 项奖励
4 条消息(共 4 条)
4,578 次查看
