You would need to change the following
1.Use another IMAQ Create VI to create a separate image for the Resampled Image
2. Make sure that your front panel image has Snapshot Mode enabled
谢谢,我重新修改了程序,图片显示了,但是没有找到“zoom to fit ”这一选项,所以有时候会出现下面这个情况:
前面板要么是原图显示空白,要么是重新采样空白.....运行时间一长就说图片不够大,这种情况是什么原因啊?还有那个zoom to fit 是因为我版本太低的原因吗?我用的才是Vision 7.0..........
Could you post the image that you are working with?
Zoom-to-fit option was a new feature implemented in NI Vision 8.6 so it does not seem like you would have that funtionality. Nevertheless, if you can post the image that you are using, I can try to see if the same error is observed in LabVIEW 2009.
