NI Labs Discussions
LabVIEW FPGA Advanced Session Resources Feedback
FYI, the installer for LV 2018 has been added https://forums.ni.com/t5/NI-Labs-Toolkits/LabVIEW-FPGA-Advanced-Session-Resources/ta-p/3500447
Andres G
Message 61 of 66
(4,327 Views)
Is this project dead?  Is there a 2020 or 2021 version available?
-Derek Roane
Message 62 of 66
(3,927 Views)
Hello, will there be the 2020 version?
Message 63 of 66
(3,882 Views)
I don't know about any new version of it, it would be up to NI to announce it.
But if you need it in 2020, what you can try is installing the last version available and cut+paste the files in the LV2020 corresponding folders.
If you go through the thread, if I remember well, the procedure is explained.
Not the best solution, but it worked for me on previous LV versions.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 64 of 66
(3,879 Views)
Thanks CyGa, I had some problems with moving the code from earlier version, but your post encouraged me to try it again - and I made it work in 2020.
Message 65 of 66
(3,866 Views)
I have a problem with the palette being broken after installing the 2019 vip:
VIs seem to be missing...
Message 66 of 66
(3,504 Views)
