03-01-2012 08:31 PM
1. We will consider each features defined by opc ua, but cannot gaurantee if a specific feature will be implemented in the future or not. It depends on the requirement and feedback. So, how do you want to use the method? What kind of use case it is?
2. It's because this is just a web download, which is not integrated into our runtime engine. So, the runtime engine doesn't include the required VI and library.
 opcua
			opcua
			03-05-2012 01:49 PM
Uploaded again: 2e8ca801-2992-4c54-92ec-05c7e0cffb6e.zip
Here is the contents
| -rw-rw-rw- 1 xxxx | root | 82 Apr 5 2012 2e8ca801-2992-4c54-92ec-05c7e0cffb6e.txt |
| -rw-rw-rw- 1 xxxx | root | 93573 Apr 5 2012 aa5df164-e271-4532-808f-094366cb38ec.dmp |
| -rw-rw-rw- 1 xxxx | root | 629 Apr 5 2012 lvlog.txt |
Hope this works
Thanks for your help.
 opcua
			opcua
			03-05-2012 02:36 PM
Thanks, Ryan, for your consideration.
UC#1: support object address space browsing, from root, ie. i=84. This support will enable client to test connectivity and to know the capability and the namespaces and variable naming scheme of the server application.
The server will list all the direct child nodes for a given node.
UC#2: On realtime engine, ex. cRIO, the server should return discovered URL with its IP, instead of localhost.
03-05-2012 09:22 PM
The crash in the memory dump seems to be a known issue which has already been fixed.
Can you give me your client program, and tell me how to set it up? I want to reproduce the crash.
 opcua
			opcua
			03-06-2012 09:58 AM
Thanks Ryan, for looking into this.
I've uploaded the java program: myclient.java.
I could not upload the ProsysOPC jar. They are evaluation copy and expired. You can download from their site.
 Tonch
			Tonch
			03-06-2012 10:17 AM
Thanks for your answers. About methods, the point is to substitute the use of variables to do action, like commercial PLC. In my environment I have a commercial SCADA system that communicates using OPC DA with a intermediate level; this level transforms the OPC variables into tcp/ip commands or datasocket read/write depending on the field protocol. Commands are trasferred using set/reset of variables. Now we are programming and testing the evolution of this architecture. To have or not methods changes the approach. Obviously we can continue with set/reset of variables.
Sandro
 opcua
			opcua
			03-07-2012 06:44 AM
Forgot to mention that to reproduce the issue,
1. start Server.vi from the download; I am using 2011 Evaluation copy.
2. run the java client on the same box. My test is run on Windows XP.
03-08-2012 01:34 AM
thank you. I have got the SDK from prosys. I'll try to set it up.
 dwisti
			dwisti
			03-21-2012 12:58 PM
Since OPC UA is now shipping with LabVIEW 2011 SP1 DSC and Real-Time Module, I guess this API has graduated out of NI Labs. Is the shipping version in 2011 SP1 the same? Has any new features been added? If not, when can we expect any updates or new features to the API. I almost forget to mention, thanks for making this a free API with RT and DCS.
03-21-2012 09:41 PM
Basically it's same. It includes some bug fix. It also addes a new VI to create certificate.
