NI Labs Discussions
NI Multisim Laboratory Exercise Wave-Shaping with Diodes
I'm trying to construct this circuit from a National Instruments laboratory exercise:
(Image from National Instruments)
However, the transformer "TS_PQ4_16" is one that I can't seem to find in Multisim 14.0.  I've been through several iterations of the search function, and I think it must have been renamed (or deleted).  I've tried several similar-looking transformers, but I have no way of knowing for sure which transformer is indicated for use here.  Apparently the transformer above was a component in Multisim 10, but that's all I can find. Is there a way to determine which Multisim 14.0 component is analogous (or is exactly) the component I'm looking for, if there is a way at all?
(4,389 Views)
The TS_PQ4_16 is no longer in the database. The transformer database was change, I believe in Multisim 12. I suggest you use the "TS_Virtual" which is located in the "Basic Virtual" family. These models are the same, and the only difference is you can change the turn ratio with the TS-Virtual and not the TS_PQ4_16.
Tien P.
(3,993 Views)
