NI Labs Discussions
Using labview as a Scanner in a Ethernet/IP connection
Hello NI world,
I want to use the labview Ethernet/IP software to make a connection with a fanuc robot.
After some research i decieded that the Ethernet/IP protocol would be nice to use because of the comprehensive manual they give you.
The robot only has an adapter option though.
I would like to know if it is possible to setup the labview Ethernet/IP software in a scanner functionality.
And if it is possible, how can i do it?
Is there special hardware required?
Is there special software required?
etc.
Big tnx for the one that can help me out
Greetings,
Emiel Nijssen
Student Mechatronics
Message 1 of 1
(4,299 Views)
