NI Labs Discussions
NI VeriStand FPGA-Based I/O Interface Tools Discussion
Yes you could do that. I will require some custom FPGA and XML code made by you.
You basically want to add an IO property node to the diagram where you set the IO mode programmatically. You can then add a parameter to each of your analog IO channels so you can tune this from system explorer as a parameter.
If you go to the RIO library and see one of the specialty analog modules like the 9234, this technique is used to set the rate of the module. You will want to do something similar
Stephen B
Message 71 of 91
(8,060 Views)
Yes, I would like to add an IO property node to the diagram and set the value programmatically from a Veristand channel parameter. I understood how to add a parameter to a channel thanks to your answer and the Veristand help.
It remains one problem, none property or method is available in my LabVIEW FPGA diagram for the analog inputs of the PXI-7841R board.
Is it possible to modify the configuration mode programmatically for the PXI-7841R device? Have you got an exemple?
Best regards
Message 72 of 91
(8,059 Views)
Hey DMous,
This is more of a LV FPGA question. I would search the help. Its there somewhere. Alternatively you can contact support at ni.com/support
Stephen B
Message 73 of 91
(8,059 Views)
I have a question about .fpgaconfig file.
Are there manual for how to write .fpgaconfig file?
Or, are there any tools that automatically creates .fpgaconfig file?
The reason why I am asking is when the customer want to create more packets (about 60 packets), he needs manually edited .fpgaconfig file by himself.
It did not work properly at first, but when he upside-down the order of packets, it began working.
They are wondering what was wrong with .fpgaconfig file.
Please let me know if you have any information for this behavior.
Haruka
Message 74 of 91
(8,059 Views)
Hi Stephen,
I have some doubts regarding how develop CAN communication using the tool.
Based on to the CAN communication be used in Veristand to send and receive frames and perform actions according to the frames received.
To create FPGA-Based I/O personalities I am using FPGA XML Builder Node Add-on.  Using this add-on or the other way using DMA´s the input and output that I can connect are AI (analog input), AO, DI and DO (Digital output). But I will like to work with the CAN module N-9853 that give me and output in cluster mode or U6 32 array.
My firs doubt:
I don´t see how I can implement that customizing FPGA interface
This is the code that I have developed for the FPGA for read/write using the module N-9853.
And this is how I develop the read/write in Real Time in labview
Finally some other doubts:
Is it possible to do this using Veristand? Is it possible to link programs from labview with veristand? If yes, How would be they communicated for data transfer?
Thank you in advance!!
Message 75 of 91
(8,059 Views)
Hi, I am using cRIO 9038 (RT Linux64) with NI 9381 (AIO/DIO) in slot 1. I created a fpga personality and added to a VeriStand project. Everything went smoothly until I tried to deploy it. I am getting the following error.
Details:
Error 61060 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW FPGA:  The Wait on IRQ method timed out before the specified interrupt was received.
NI VeriStand:  FPGA DMA.lvlib:Wait on IRQ from FPGA.vi:3760001<APPEND>
Complete call chain:
     HP Loop.lvlib:HP Loop Main.vi
     NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi
     NI VeriStand Engine.lvlib:VeriStand Engine.vi
     NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi
I only modified the input and output section of the template. Any suggestion is appriciated.
Thanks.
Message 76 of 91
(8,070 Views)
Hi mtitoo, I got excatly the same issue as yours, VeriStand keeps telling me about this time out error. Did you solve this problem in the end?
Thanks.
Message 77 of 91
(8,071 Views)
Hi Ethanlu2, I have not got a chance to play with this tool. However, I was talking to one of our fellow LabVIEW experts on that issue yesterday and he pinpointed one probable cause for this. When template generates the FPGA project, the incoming packet number is 11, however I had only 4 packets but forgot to change the for loop iteration from 11 to 4. Did you have something like that? If you had, make sure FIFO read iteration matches your number of packets in XML file and give it a try.
Message 78 of 91
(8,072 Views)
That's exactly the mistake I have made. Thank u so much.
Message 79 of 91
(8,073 Views)
My customer is trying to understand how Custom Personality FPGA.vi in the template works. Specifically, he is looking at Packet 1 free label section of the diagram where the output "Is Late?" from "NI VeriStand - Synchronize to Host.vi" is written to "NI VeriStand - Send Packet to Host.vi"  as Packet 1. In Custom Personality.fpgaconfig file, Packet 1 is not included in the channel of system definition file. In order to look at Packet 1 information, does he need to modify fpgaconfig file manually, or is there any way to look at it since it is written to DMA FIFO?
Also, "8 PulseMeasurements.vi" has Timeout as input parameter. What happens to the output values when timeout occurs? We were looking at the following help document but PWM in the table doesn't indicate default value.
http://zone.ni.com/reference/en-XX/help/372846J-01/veristandmerge/creating_custom_fpga_configuration...
By the way, above help says that default value for offset is 1. Is this supposed to be 0 instead of 1?
Michi
Message 80 of 91
(8,078 Views)
