NI Labs Discussions
Welcome to the IP Integration Node
Generics are not officially supported however we are trying to get this implemented in the actual release.
The VHDL portlist must only contain std_logic and std_logic_vector ports. You then select on the last page of the IP Integration Node how LabVIEW should interpret those bits. I would recommend taking your VHDL and creating a wrapper entity that converts the integer arrays to std_logic_vector. Then in LabVIEW have this mapped to a Boolean array. Then post process this boolean array into sub-arrays the size of the original vhdl integer elements. Then convert these Boolean sub-arrays into integers using the "Boolean Array To Number" function. These conversions are merely datatype reinterpretations and do not consume any resources (besides development time:-).
Message 21 of 69
(2,781 Views)
well, i do have some issue with wrapper file. however,presenly these is one more issue.
i was trying to implement convolution in ip node. although,earlier i wrote a vhdl program using integer arrays, it wont work without creating wrapper file.
so, i wrote another code using std_logic_vector in ascending range( lsb left,msb right) as input,output. but, i have seen that in convolving say [ 3 2] with [ 4 5 6], instead of [ 12 23 28 12] as result,
i was getting all blank. however, if i enter the inputs in descending range in labview ( vhdl code unchanged), i get correct result( read in descending range way again).
any explanation?
this made be experiment with how labview takes array range . again, i have very conflicting results.
i have attached relevant project, with 2 vi's convolution_by_by_bit and array_dir ,with vhdl files.
please run them,and see the results. i have also put snapshots of what is expected,and Modelsim simulation results.
thanks
sidharth
signal and image processing lab
UTD
Message 22 of 69
(2,781 Views)
Good point. I believe your experiments have reverse engineered how the std_logic_vector is defined in LabVIEW FPGA: std_logic_vector(kLength-1 downto 0). So when you have a port on your vhdl like std_logic_vector(0 to nx-1), I believe this effectively reverses your bits from an indexing perspective. Bit kLength-1 of the LabVIEW signal is now bit 0 inside your entity. I believe the moral of the story is the std_logic_vectors on your wrapper file should be using the downto indexing in order to stay consistent with how lv fpga orders the bits.
Message 23 of 69
(2,781 Views)
Hi NewtonPetersen,
I am using IP node for my LabVIEW FPGA project. I am getting declaration errors when I try to use fixed point numbers in VHDL code.
I will explain this problem using simple VHDL program of adding two unsigned fixed point numbers and assigning the result to a fixed point number.
Errors for the program shown below
ERROR:HDLCompiler:69 - "fix_pt.vhd" Line 9. u_ufixed is not declared
ERROR:HDLCompiler:69 - "fix_pt.vhd" Line 10. u_ufixed is not declared
ERROR:HDLCompiler:69 - "fix_pt.vhd" Line 11. u_ufixed is not declared
my vhdl program is:
library ieee_proposed;      --library which contains fixed_pkg
library ieee;
use ieee.std_logic_1164.all;
use ieee_proposed.fixed_pkg.all;
entity fix_add is
  port(
        a: in u_ufixed(3 downto -3);   --Taking wordlength as 7 and integer length as 4
        b: in u_ufixed(3 downto -3);     --Taking wordlength as 7 and integer length as 4
        c: out u_ufixed(4 downto -3)   --Taking wordlength as 8 and integer length as 5
end entity;
architecture behaviour of fix_add is
begin
  c<=a+b;
end architecture;
The same program compiled and simulated successfully in Model SIM, ofcourse I changed the library declarations,as ModelSIM contains 'fixed_pkg' in different library.
I thought these errors are occuring due to non declaration of libraries,but I declared libraries in my program .
Is there any mistake in my declaration ?What is problem with this program?
Thanks.
Message 24 of 69
(2,781 Views)
When I look in C:\NIFPGA2009\Xilinx\ISE\vhdl\src\ieee_proposed\fixed_pkg_c.vhd, I do not see a u_ufixed type. There is a ufixed type; perhaps it is the same thing. Just a reminder, in the IP Integration Node, all the toplevel ports must be of type and format: std_logic_vector(kLength-1 downto 0). You can use whatever types you want below the toplevel. I also recommend compiling your VHDL code in a xilinx ISE project before trying to integrate it into the IP Integration Node as it will be easier to track down syntax errors.
Message 25 of 69
(2,781 Views)
Thanks it worked ,I changed the u_ufixed to ufixed.
Message 26 of 69
(2,781 Views)
I have two issues to bring up about the IP integration node.
1.  If a compile is unsuccessful, the user has to rebuild the IP integration node completely.  This isn't a very big deal if the number of files being referenced is small, but if it's large then it becomes fairly time consuming to regather the files.  There should be a way to save the list of files being referenced so that the user doesn't have to find all of the files every time until the compilation is successful.
2.  I am getting the following error after a fairly large compilation.
Generated simulation model successfully!
Error:<APPEND>
C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\rvi\NIPI\dialog\BasicSetting\nipi_GetModuePortInfo.vi
<b>Additional Information:</b> The IP has no ports or the IP has expressions that this node doesn't support.
Any advice on this?
Thanks!
Message 27 of 69
(2,781 Views)
For 1, good suggestion.
For 2, can you attach the VHDL that displays this problem?
Message 28 of 69
(2,781 Views)
Newton,
I can't post all of my code due to IP restrictions.  Here is the top-level entity declaration. I'm not too sure if this will help you out.  I was able to successfuly use the IP integration nodes with the sub-components of this design, so my guess is that the error is somewhere in doppler_one_path.vhd
entity  doppler_one_path is
port(
  clk               : in  std_logic;
  srst              : in std_logic;
  ready_in           : in std_logic;
  data_valid_in     : in std_logic;
  data_in           :  in std_logic_vector(35 downto 0);
  ready_out          : out std_logic;
  data_valid_out    : out std_logic;
  data_out           : out std_logic_vector(35 downto 0);
  delta_t           : in  std_logic_vector(49 downto 0);
  doppler_scale     : in std_logic_vector(24  downto 0);
  awgn_scale        : in std_logic_vector(24 downto  0);
  doppler_tap_in    : in std_logic_vector(24 downto  0);
  doppler_tap_index : in std_logic_vector(9 downto  0);
  doppler_tap_set   : in std_logic;
  skip_doppler      : in  std_logic
end doppler_one_path;
Message 29 of 69
(2,781 Views)
thill,
The IP Integration Node reported this error because the xilinx tool couldn't extract the ports information from your  top level vhdl file. I created an empty module with your port list:
library ieee;
port(
  clk               : in  std_logic;
architecture rtl of doppler_one_path is
begin
end rtl;
The IP Integration Node worked for this mockup case. So I recommend you to review your top level vhdl file to see if there are any expressions that Xilinx doesn't support well.
Message 30 of 69
(2,781 Views)
