NI Linux Real-Time Discussions
Showing results forĀ
Search instead forĀ
Did you mean:Ā
CAN Frame channel conversion library on linux RT
how can i to use .dbc file on linux RT?
i see that on linux RT the CAN frame channel conversion library aren't supported.
there are other libraries to use on linux RT to convert data to payload and vice versa?
regards
Valbo10
Message 1 of 9
(7,947 Views)
Can you provide us with details of the hardware you are using?
Jeff L
Message 2 of 9
(6,165 Views)
My hardware is RIOSOM 9651
Sent from my iPhone
Message 3 of 9
(6,165 Views)
How is the CAN implemented? Are you using the development mother board, a C-Series module, or a custom designed circuit?
Jeff L
Message 4 of 9
(6,165 Views)
on RIO SOM 9651 if i'm not mistaken,  it is not possible
to use C series module.
anyway, i use a custom designed circuit.
the hardware is not a problem.
the software CAN it is the same of NI sbRIO 9606: NI Embedded  CAN for sbRIO. but on linux RT the CAN Frame channel conversion library  do not work.
this tool is not compatible with new OS
when an updated version will be released?
Message 5 of 9
(6,165 Views)
Currently the CAN Frame Channel Conversion Library has been deprecated in favor of NI XNET.  We are currently looking into further to see the best method.  NI XNET has a database API that can be used.  However, XNET cannot be installed on the 9651 at this time.
I'm looking into this a bit further to see if I can find appropriate solutions.  I apologize for the delay.
Matt
Matt S.
Industrial Communications Product Support Engineer
Message 6 of 9
(6,165 Views)
I have an update:
The XNET library happens to have a XNET Convert VI, this will allow you to convert between frame and signal.  You can use the XNET library on the sbRIO 9651.  You can download XNET 14.1 here.  You can then custom install XNET to the SoM.  This is the replacement for the CAN Frame Channel Conversion Library.
Please let me know if you have any issues.  Thanks!
Matt
Matt S.
Message 7 of 9
(6,165 Views)
thanks
from two days, I realized that the Xnet can be installed on RIO SOM.
I did not know of upgraded to 14.1 XNET.
for how the Embedded CAN operate. I just have to provide ID and payload.
it is easy
disadvantages that I see using the XNET are:
1) conversion mode the output is all  the CAN frame.
2) the package to be install is more heavy than the frame to channel conversion library
3) it is more awkward to handle the file dbc. with frame to channel conversion library, I set the path, and it is done
4) it is slower during conversion.
best regards
Manuel
Message 8 of 9
(6,165 Views)
Hey Manuel,
I was just looking around and saw your post. This doesn't solve many of the issues you're experiencing but may make XNet's conversion library easier to use:
http://forums.ni.com/t5/Automotive-and-Embedded-Networks/CAN-Frame-Signal-Conversion-With-XNet/td-p/...
Daniel
Message 9 of 9
(6,165 Views)
