NI Linux Real-Time Discussions
Change OS on cdaq 9135
Goodmorning,
Is it possible to change my cdaq 9135 shipped with WES7 as OS to a realtime target?
And if yes, how?
Thank you in advance!
Kind regards,
bvrm
(3,848 Views)
Did you receive a wrong order? I don't know if that matters, just a datapoint.  Basically, contact NI's support and they can help you through that, I believe it should be just a matter of getting down some information and setting you up with instructions and the materials needed to restore the NI Linux RT image on the controller.
http://www.ni.com/support/
(3,430 Views)
I did not receive a wrong order. However my application now requires the extra feature of implementing a closed loop control. With the windows based OS I'm not able to get my daqmx read and write tasks to run in 'realtime' (+/- 1kHz). Therefore I was wondering if I could still change the OS after purchase.
Thank you for the reply.
kind regards,
bvrm
(3,430 Views)
