NI Linux Real-Time Discussions
System Exec VI Calling umount
Hi all,
I need to safe umount my FAT32 filesystem USB mass storage device, and my final customer should be able to do that from the VI Front Panel (running on cRIO-9030 with HMI enabled). I would like to run programmatically a command like:
sudo umount /dev/sdcX
but it is allowed only by admin (not by lvuser). How can I do that?
There is a way to create a bash script calling
su admin
passing directly the password, without prompting it? It seems that
su admin -p 'adminPassword'
doesn't work
Thank you in advance
Andrea
(4,331 Views)
su itself generally requires being run from a terminal (interactive), but of course you can install and configure sudo to work for any user on the system, including lvuser (the user that runs the LVRT runtime)
(3,974 Views)
You need to add your user to sudoers by Visudo command
CLA, CTA
(3,974 Views)
