NI Linux Real-Time Discussions
Ethernet connection kills wifi
Hi everyone,
when I connect the ethernet cable to myrio the wifi switch off.I think I should change the IP address:
now it's 192.168.0.50 for the ethernet and 192.168.0.197 for wifi.
The actual configuration is sbRIO9636->ethernet->myRIO1900->wifi->modem.
The sbrio sends data to myrio which writes them into a txt file.Since it is connected to a modem I can reach the txt file from the  http://myrioip/files .Everything works if the myrio is connected to the pc by usb cable (172.22.11.2 is the IP with USB cable) but when I connect myRIO to sbRIO the wifi stops to work and the ethernet works.
Thanks!
(2,836 Views)
How are you connecting Ethernet to myRIO? It doesn't have an Ethernet port. Are you using a USB Ethernet adapter connected to the USB host port?
You have two network adapters configured with 192.168.0.50 and 192.168.0.197. What netmask are you using? With a netmask of 255.255.255.0 then the routing table[1] will have two routes for the 192.168.0.0/24 network, and it sounds like the Ethernet interface has priority. Consider moving one to a separate IP network (for example, one of them as 192.168.0.50 and the other as 192.168.1.197) to avoid this conflict.
[1] You can examine this with the "route" command.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(2,820 Views)
