NI Linux Real-Time Discussions
SNMP for CRIO 9068 LinuX RT
Does the CRIO 9068 LRT come with SNMP agent already installed? If not, is it possible to compile the Net-SNMP source code using the NI Eclipse edition and install it.
T
Message 1 of 9
(8,115 Views)
ttesfay,
The cRIO 9068 does not include a SNMP agent as-is, and you could certainly build one through Eclipse, but you have an easier option: enable the on-controller package manager and install community software through it.
Read over the FAQ for some background information on the package manager then try a command along the lines of "opkg list | grep -i snmp" to get an idea of the packages that you have available to you
Message 2 of 9
(6,335 Views)
Unfortunitely, after taking a quick look, there doesn't appear to be any snmp clients available from the angstrom package repo.
Could you perhaps implement one in python or perl?
Additionally, the BeagleBone eco-system is very similar to that of the version of Linux on the cRIO.  You may have some success following this tutorial:
http://www.cloud-rocket.com/2013/08/compiling-and-installing-net-snmp-for-beaglebone/
Good luck!
-TD
Message 3 of 9
(6,335 Views)
You sure?
admin@Nick-9068:~# opkg list | grep -i snmp
cups-backend-snmp - 1.4.6-r0.9 - cups backend for snmp
libnetsnmp25 - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
net-snmp-client - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
net-snmp-dev - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
net-snmp-mibs - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
net-snmp-server - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
net-snmp-static - svn-r7.2.9 - Various tools relating to the Simple Network Management Protocol
admin@Nick-9068:~#
Make sure to enable the repos and run opkg update.
Message 4 of 9
(6,335 Views)
Whelp, looks like someone formatted my cRIO-9068 and reset the /etc/opkg/angstrom-base-feed.conf file ... my appologies.
Looks like net-snmp-dev may be a good stating point for calling snmp functions.  If you can getaway with the overhead, you may want to look into using System Exec.vi and the snmp client from the CLI.
-TD
Message 5 of 9
(6,335 Views)
To add to tduffy's response, certainly if you can deal with the overhead of calling the SNMP utilities through Exec rather than a CLN interface, it is far simpler. I have some wrappers I wrote years ago that work with the version of the SNMP utilities that Cygwin shipped at the time. I would guess that they would continue to work here since the command line paramaters have likely not changed.
Of course you said mentioned you wanted to be an agent and not a manager, so these VIs might not help you since they just wrap the typical snmpget/set/walk utilities, but I'll post in case they are useful:
https://decibel.ni.com/content/servlet/JiveServlet/downloadBody/36560-102-1-70690/SNMP%20Wrappers.zi...
Message 6 of 9
(6,335 Views)
BlueCheese,
These are great!  Thank you so much for posting!
ttesfay,
If you end up using these, and they work as-is, could you post back to let us know?
-TD
Message 7 of 9
(6,335 Views)
Which parameters can I monitor?
Message 8 of 9
(5,223 Views)
I have installed snmp-agent from all snmp packet from repo, I wish read informations about cpu and memory, but I can see only stupid OID:
iso.3.6.1.2.1.1.1.0 = STRING: "Linux NI-cRIO-9068-chaos 3.14.46-rt46-ni-3.5.0f0 #1 SMP PREEMPT RT Tue Jan 19 21:49:05 CST 2016 armv7l"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.8072.3.2.10
iso.3.6.1.2.1.1.3.0 = Timeticks: (486710) 1:21:07.10
iso.3.6.1.2.1.1.4.0 = STRING: "Root <root@localhost> (configure /etc/snmp/snmpd.local.conf)"
iso.3.6.1.2.1.1.5.0 = STRING: "NI-cRIO-9068-chaos"
iso.3.6.1.2.1.1.6.0 = STRING: "Unknown (configure /etc/snmp/snmpd.local.conf)"
iso.3.6.1.2.1.1.8.0 = Timeticks: (1) 0:00:00.01
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.11.3.1.1
iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.15.2.1.1
iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.10.3.1.1
iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.1
iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.2.1.49
iso.3.6.1.2.1.1.9.1.2.6 = OID: iso.3.6.1.2.1.4
iso.3.6.1.2.1.1.9.1.2.7 = OID: iso.3.6.1.2.1.50
iso.3.6.1.2.1.1.9.1.2.8 = OID: iso.3.6.1.6.3.16.2.2.1
iso.3.6.1.2.1.1.9.1.2.9 = OID: iso.3.6.1.6.3.13.3.1.3
iso.3.6.1.2.1.1.9.1.2.10 = OID: iso.3.6.1.2.1.92
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB for Message Processing and Dispatching."
iso.3.6.1.2.1.1.9.1.3.2 = STRING: "The management information definitions for the SNMP User-based Security Model."
iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The SNMP Management Architecture MIB."
iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB module for SNMPv2 entities"
iso.3.6.1.2.1.1.9.1.3.5 = STRING: "The MIB module for managing TCP implementations"
iso.3.6.1.2.1.1.9.1.3.6 = STRING: "The MIB module for managing IP and ICMP implementations"
iso.3.6.1.2.1.1.9.1.3.7 = STRING: "The MIB module for managing UDP implementations"
iso.3.6.1.2.1.1.9.1.3.8 = STRING: "View-based Access Control Model for SNMP."
iso.3.6.1.2.1.1.9.1.3.9 = STRING: "The MIB modules for managing SNMP Notification, plus filtering."
iso.3.6.1.2.1.1.9.1.3.10 = STRING: "The MIB module for logging SNMP Notifications."
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.6 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.7 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.8 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.9 = Timeticks: (1) 0:00:00.01
iso.3.6.1.2.1.1.9.1.4.10 = Timeticks: (1) 0:00:00.01
iso.3.6.1.2.1.1.9.1.4.10 = No more variables left in this MIB View (It is past the end of the MIB tree)
Can I resolve it?
Message 9 of 9
(5,212 Views)
