03-29-2016 11:18 AM
I had successfully loaded Gnuplot on a 9033 which has a 64 bit architecture. The gnuplot package was included in the opkg update from NI. However I now have a 9066 which is an ARM and Gnuplot is not listed in the feed. I forced the feed to the x64 and of course it won't load becuase it is not comptaible with the ARM architecture.
Can anyone suggest a feed that has gnuplot.ipk for ARM or help me work through loading an uncompiled gnuplot tarball to the 9066 and then compiling there. I have done a quick search on the internet and it seems possible to compile gnuplot on an ARM device.
Solved! Go to Solution.
03-29-2016 12:54 PM
I am trying to compile using gcc and I get an error that says my compiler can't create executables...
Taken frm the config.log in the gnuplot folder...
./configure: line 3347: /usr/lib/gcc: Is a directory
configure:3349: $? = 126
configure:3386: result:
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "gnuplot"
| #define PACKAGE_TARNAME "gnuplot"
| #define PACKAGE_VERSION "4.4.1"
| #define PACKAGE_STRING "gnuplot 4.4.1"
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define PACKAGE "gnuplot"
| #define VERSION "4.4.1"
| /* end confdefs.h. */
| #include <stdio.h>
| int
| main ()
| FILE *f = fopen ("conftest.out", "w");
| return ferror (f) || fclose (f) != 0;
| return 0;
configure:3392: error: in `/home/lvuser/gnuplot-4.4.1':
configure:3396: error: C compiler cannot create executables
See `config.log' for more details.
03-29-2016 02:46 PM
I think there's a key in this output:
Check the actual configure script, line 3347. It seems like the script is trying to use the directory as an executable?
How did you install the tools to attempt to build gnuplot?
03-29-2016 03:27 PM
Well, I am VERY new to this all so at first I tired:
opkg install gcc
that didn't work. I then tried
opkg install gnupg
that didnt work. I found another NI forum post https://decibel.ni.com/content/thread/20236?start=15&tstart=0 and someone in there pointed out that gcc, etc. wouldn't have all the dependencies, and suggested
opkg update
opkg install packagegroup-core-buildessential
After doing this I downloaded the gnuplot source files and extracted to the main folder and then was able to use
./configure
make
make install
Much to my delight IT WORKED!!!!! I now now have a compiled version of gnuplot for my armv7-A architecture!
03-29-2016 03:50 PM
Now, the next thing to do is to compile this off the target and then just move gnuplot to the target so I don't eat of memory with the compiler and any overhead it my bring with it.
Any suggestions? I am running a virtual machine with Fedora 23 on it.
03-29-2016
04:21 PM
- last edited on
10-09-2025
08:13 AM
by
Content Cleaner
With this next step, there are realistically two venues to take: using the tools that can cross-compile for the target or use the same build infrastructure that NI uses for building the images and package feeds themselves.
The latter is a bit more complex but it closer to what is done internally, mostly useful if you want to make a wide-spread change to the actual base image. This is probably more than you wanted to tackle, but if you wanted to try this out you will need your VM since it's Linux-only. There are instructions that acccompany the version of the OS image that you are working with, use git to clone that repository down and checkout the branch that matches what you are using for the correct instructions.
The other, which is a bit more one-off, would be to take the packaged tools that NI provides for cross-compiling for the targets and using either a project building system/IDE (e.g. Eclipse) or creating a cross-compilation project in a text-based alternative (e.g. CMake).
The tools can be downloaded here (note that 2014 is the most recent version of the tools):
Windows (ARM and x64 w/ Eclipse): https://www.ni.com/en/support/downloads/software-products/download.c-c---development-tools.html#3334...
Linux (ARM and x64 w/o Eclipse): https://www.ni.com/en/support/downloads/software-products/download.gnu-c---c---compile-tools-for-arm...
Getting started guide (Windows-centric): https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHR7CAO&l=en-US
There's a good chance that you'll have some questions, be sure to ask them on the forums as I'm sure others have the same questions (or have already solved that issue).
03-30-2016 10:52 AM
Wow, Eclipse makes my head hurt.
03-30-2016 11:03 AM
As bad as it is, it's usually easier to fix an issue with the build in Eclipse than it is to fix the issue in OpenEmbedded. Of couse, this statement is tantamount to saying that Moe was the smartest of the Three Stooges.
05-04-2016 09:42 AM
Eventhough I was able to get gnuplot to compile directly on the target, I found that it was missing some libraries required to use the PNG terminal. After some digging around on the internet I found that I needed 'libgd' which is a support library for graphics drivers. Before I could use libgd properly I needed to compile another library called 'libpng', which went smoothly using "./configure", "make", "make install".
However when I went to compile the 'lingd' I noticed that the PNG library wasn't loading properly. To finally get it working properly I had to force the libpng location.
admin@NI-cRIO-9066-030c6c27:/home/lvuser# cd /home/lvuser/libgd-2.1.1
admin@NI-cRIO-9066-030c6c27:/home/lvuser/libgd-2.1.1# ./configure
** Configuration summary for libgd 2.1.1:
Support for Zlib: yes
Support for PNG library: no
Support for JPEG library: no
admin@NI-cRIO-9066-030c6c27:/home/lvuser/libgd-2.1.1# find / -name libpng
/home/lvuser/libpng-1.6.21/projects/vstudio/libpng
admin@NI-cRIO-9066-030c6c27:/home/lvuser/libgd-2.1.1# ./configure --with-png=/usr/local/
Support for PNG library: yes
Support for VPX library: no
Support for TIFF library: no
Support for Freetype 2.x library: no
Support for Fontconfig library: no
Support for Xpm library: no
Support for pthreads: yes
admin@NI-cRIO-9066-030c6c27:/home/lvuser/libgd-2.1.1# make
admin@NI-cRIO-9066-030c6c27:/home/lvuser/libgd-2.1.1# make install
After success compile of 'libgd' it was time to recompile 'gnuplot'
admin@NI-cRIO-9066-030c6c27:/home/lvuser# cd /home/lvuser/gnuplot-4.4.1
admin@NI-cRIO-9066-030c6c27:/home/lvuser/gnuplot-4.4.1# ./configure
** Configuration summary for gnuplot 4.4.1:
gnuplot will be compiled with the following terminals:
Standalone terminals: yes (always builtin)
(canvas, cgm, corel, dumb, dxf, eepic, emf, emtex,
epslatex, epson_180dpi, epson_60dpi, epson_lx800, fig, gpic, hp2623A,
hp2648, hp500c, hpdj, hpgl, hpljii, hppj, imagen,
latex, metafont, metapost, mif, pbm, postscript, pslatex, nec_cp6, okidata,
pcl5, pstex, pstricks, qms, regis, svg, tandy_60dpi,
tek40xx, tek410x, texdraw, tgif, tkcanvas, tpic, vttek)
X Window System terminal: no (requires X libraries)
jpeg terminal: no (requires libgd with jpeg support)
gif terminal: yes (with animated gif)
png terminal: yes
(jpeg, gif and png terminals cannot use TTF fonts, requires libgd support)
admin@NI-cRIO-9066-030c6c27:/home/lvuser/gnuplot-4.4.1# make
admin@NI-cRIO-9066-030c6c27:/home/lvuser/gnuplot-4.4.1# make install
admin@NI-cRIO-9066-030c6c27:/# gnuplot
G N U P L O T
Version 4.4 patchlevel 1
last modified Fri Sep 10 12:10:34 PDT 2010
System: Linux 3.2.35-rt52-2.0.0f0
Copyright (C) 1986-1993, 1998, 2004, 2007-2010
Thomas Williams, Colin Kelley and many others
gnuplot home: http://www.gnuplot.info
faq, bugs, etc: type "help seeking-assistance"
immediate help: type "help"
plot window: hit 'h'
Terminal type set to 'unknown'
gnuplot> set terminal
Available terminal types:
canvas HTML Canvas object
cgm Computer Graphics Metafile
corel EPS format for CorelDRAW
dpu414 Seiko DPU-414 thermal printer [small medium large]
dumb ascii art for anything that prints text
dxf dxf-file for AutoCad (default size 120x80)
eepic EEPIC -- extended LaTeX picture environment
emf Enhanced Metafile format
emtex LaTeX picture environment with emTeX specials
epslatex LaTeX picture environment using graphicx package
epson_180dpi Epson LQ-style 180-dot per inch (24 pin) printers
epson_60dpi Epson-style 60-dot per inch printers
epson_lx800 Epson LX-800, Star NL-10, NX-1000, PROPRINTER ...
fig FIG graphics language for XFIG graphics editor
gif GIF images using libgd and TrueType fonts
gpic GPIC -- Produce graphs in groff using the gpic preprocessor
hp2623A HP2623A and maybe others
hp2648 HP2648 and HP2647
hp500c HP DeskJet 500c, [75 100 150 300] [rle tiff]
hpdj HP DeskJet 500, [75 100 150 300]
hpgl HP7475 and relatives [number of pens] [eject]
hpljii HP Laserjet series II, [75 100 150 300]
hppj HP PaintJet and HP3630 [FNT5X9 FNT9X17 FNT13X25]
imagen Imagen laser printer
mf Metafont plotting standard
mif Frame maker MIF 3.00 format
mp MetaPost plotting standard
nec_cp6 NEC printer CP6, Epson LQ-800 [monocrome color draft]
okidata OKIDATA 320/321 Standard
pbm Portable bitmap [small medium large] [monochrome gray color]
pcl5 HP Designjet 750C, HP Laserjet III/IV, etc. (many options)
png PNG images using libgd and TrueType fonts
postscript PostScript graphics, including EPSF embedded files (*.eps)
pslatex LaTeX picture environment with PostScript \specials
pstex plain TeX with PostScript \specials
pstricks LaTeX picture environment with PSTricks macros
qms QMS/QUIC Laser printer (also Talaris 1200 and others)
regis REGIS graphics language
starc Star Color Printer
svg W3C Scalable Vector Graphics driver
tandy_60dpi Tandy DMP-130 series 60-dot per inch graphics
tek40xx Tektronix 4010 and others; most TEK emulators
tek410x Tektronix 4106, 4107, 4109 and 420X terminals
Press return for more:
texdraw LaTeX texdraw environment
tgif TGIF X11 [mode] [x,y] [dashed] ["font" [fontsize]]
tkcanvas Tk/Tcl canvas widget [perltk] [interactive]
tpic TPIC -- LaTeX picture environment with tpic \specials
unknown Unknown terminal type - not a plotting device
vttek VT-like tek40xx terminal emulator
xterm Xterm Tektronix 4014 Mode
gnuplot>
