NI Linux Real-Time Discussions
How to set kernel boot parametes?
Hi, I want to set a kernel parameter (mem), for testing reasons. (I want to limit the physical memory avaliable)
I know the general procedure for normal Linux Distros, but I havent been able to get the NI Linux to take my kernel parametes.
Projektingenieur
Restbust, Simulations and HiL development
Custom Device Developer
(3,632 Views)
Accepted by ypi
On 64-bit x86 targets you can add additional kernel parameters by editing the otherbootargs variable in /boot/runmode/bootimage.cfg.
On ARM/Zynq based targets (e.g. cRIO-906x) you can add additional parameters by setting the othbootargs variable using fw_setenv othbootargs ...
(3,601 Views)
Thanks 🙂 that worked
Projektingenieur
(3,570 Views)
