NI Linux Real-Time Discussions
How to set kernel boot parametes?
Hi, I want to set a kernel parameter (mem), for testing reasons. (I want to limit the physical memory avaliable)
I know the general procedure for normal Linux Distros, but I havent been able to get the NI Linux to take my kernel parametes.
Projektingenieur
Restbust, Simulations and HiL development
Custom Device Developer
(3,720 Views)
Accepted by topic author ypi
On 64-bit x86 targets you can add additional kernel parameters by editing the otherbootargs variable in /boot/runmode/bootimage.cfg.
On ARM/Zynq based targets (e.g. cRIO-906x) you can add additional parameters by setting the othbootargs variable using fw_setenv othbootargs ...
(3,689 Views)
Thanks 🙂 that worked
Projektingenieur
(3,658 Views)
