NI Linux Real-Time Discussions
Recompile NI-RT source code to support third-party circuit boards?
Can we recompile according to the source code of NI-RT, then brush into the third party's ZYNQ core board, and be recognized by NIMAX, and transform it into a sb-rio?
(2,892 Views)
Hi asddef,
If you have the knowledge, time, and resources, you could likely get NI Linux Real-Time to run on third-party hardware. Just make sure you follow the licensing.
It's not possible to have third-party software show up in NI MAX as an NI Device. Doing so would be inadvisable at best. If you want a custom board using a Zynq chip with NI Linux Real-Time that shows up in NI MAX and allows programming from LabVIEW, I would recommend looking into the sbRIO-9651 System on Module.
Charlie J.
(2,841 Views)
Thank you for your reply. The more I feel NI is a great company. It is a respectable and admirable attitude that technicians can patiently answer my questions when discussing issues that may infringe on NI's rights and interests. Thank NI staff for answering my technical questions.
(2,820 Views)
