02-14-2025 08:59 AM
I'm running a TCP server task that I would like to start using with TLS. Are there any recommended locations or native services for storing the associated certificates? Assume these certificates need to be accessible by lvuser in order to read them into the LabVIEW application for setting up the TLS protocol.
Solved! Go to Solution.
02-17-2025 11:34 AM
The recommended certificate storage for Linux is /etc/ssl/certs. I confirmed this with our NILRT engineers, and found several good resources on how to do this by searching for "Linux Distribution certificate store".
In his presentation at our last conference, Tim Cannon shared several tools he's built, some of which store data to secure locations, but these were mostly Windows based. It's worth looking at hsi presentation at Security Tools for LabVIEW - TSS Oct 2024 - NI Community.
You can also consider using the TPM chip. If you are PXI, there is a TPM chip in your controller. We have not had TPM in cRIO, but I do have a cRIO-9048 now available with a TPM, contact me and we'll talk about it. Future cRIOs will have TPMm chips available. (steve.summers@emerson.com).
10-29-2025 03:11 PM
Following up on this...after placing a certificate in the suggested location, are any commands necessary to add/update the trusted certificate store? In my research I found the following: "after adding or removing certificates, use a command like update-ca-trust extract (on Red Hat-based systems) or update-ca-certificates (on Debian/Ubuntu systems) to update the system-wide trust store and ensure all applications recognize the changes."
10-30-2025 01:45 PM
The `update-ca-certificates` script does two main things. (1) It links any certificates that have been installed by packages to several locations on the disk (eg. /usr/share/ca-certificates) into the system cert store (/etc/ssl/certs). And (2) it then bundles those certificates into the `/etc/ssl/certs/ca-certificates.crt` certificate bundle - which is used by many programs to load "all the valid certs" at once.
Installing an organizational certificate directly into your system cert store (/etc/ssl/certs) as a part of your deployment should be fine. You should also be able to put it into the local certs location: /usr/local/share/ca-certificates/.
After you install to either location, you should run `update-ca-certificates` so that it gets inserted into the certificate bundle. I believe LV uses that bundle to determine what certificates it can use.
After you run the update script, you should be able to confirm that your cert is present using openssl.
```bash
openssl verify -CAfile /etc/ssl/certs/ca-certificates.crt ${your_cert_name.crt}
04-10-2026 06:29 AM - edited 04-10-2026 06:35 AM
FYI: I want my devices to start with a self-signed certificate when they first come online so I wrote the attached function (LabVIEW 2025) to generate that using OpenSSL...
Note that the lvuser has to be added as a sudoer prior to using this (sudo and OpenSSL is normally already in place nowadays). It can be done issuing the command:
echo 'lvuser ALL=(ALL) NOPASSWD: ALL' >> /etc/sudoers
I was planning to add a conditional case for Windows that would do the same using .Net, but could not figure out how to get that done properly in LabVIEW 2025 W3 (?) so the next step is to include openssl on Windows and run the same commands there...(or perhaps someone else have written or know of a pre-existing VI for that?).
08-18-2026 01:01 PM - edited 08-18-2026 01:02 PM
The recommended steps from alex.stewart do not result in the certificates being added to the certificate bundle. The result of the update-ca-certificates command does not generate an error but it does state that 0 added and 0 deleted. I assume that means no certificates were added to the certificate bundle. To confirm, running the openssl verify command does generate an error stating the issuer could not be verified.
08-19-2026 07:00 AM
I was able to resolve my issue. I needed to add my company's full chain of certificates (intermediates and root) that my machine certificate relied on to the NI Linux RT's trusted certificates bundle. To do this, I placed the certificates in the /usr/share/ca-certificates/mozilla/ folder. I chose this folder based the certificate locations specified in the /etc/ca-certificates.conf file for other certificates. I then updated this configuration file, which seems to be a "gatekeeper" for where the 'update-ca-certificates' command looks for certificates, to include the paths to the certificates I added, ran the update command, and the new certificates were added. I was then able to make a successful TLS connection.
