Update libsqlite3-dev on OPKG
Thanks, Scott.
Message 11 of 15
(3,421 Views)
What's the difference between that and "packagegroup-core-buildessential-dev"?
Message 12 of 15
(3,421 Views)
"-dev" packages usually contain headers, static libraries and other artefacts needed if you want to do development work on the tools/libraries installed by the main package (i.e. if you want to do work on the stuff contained in packagegroup-core-buildessential)
Btw. "-dbg" has the debug symbols.
Message 13 of 15
(3,421 Views)
Accepted by Staab_Engineering
Thanks to everyone at NI for helping us figure this out. Here's our final solution for anyone else looking to get a newer version of SQLite than is currently on the opkg server:
(Note: You'll have to change the URL to point to whichever version of hte library you want.)
#!/bin/bash
# Notice:
# Due to the limited memory available on the cRio-9066, we had to first uninstall most of the NI software packages installed before running the make script.
#this is to get the dependencies necessary for the sqlite install
#wget is to make --no-check-certificate work
opkg install binutils
opkg install binutils-symlink
opkg install packagegroup-core-buildessential-dev
opkg install wget
opkg install make-dev
#get the sqlite tarball
wget --no-check-certificate https://www.sqlite.org/2015/sqlite-autoconf-3081002.tar.gz
#untar it
tar -C /home/admin/ -xf sqlite-autoconf-3081002.tar.gz
#remove the tarball
rm ~/sqlite-autoconf-3081002.tar.gz
cd ~/sqlite-autoconf-3081002
#compile sqlite
./configure
make
make install
cd ~
rm -r ~/sqlite-autoconf-3081002
Message 14 of 15
(3,421 Views)
Untested, but it might be sufficient to temporarily set overcommit to the default, instead of uninstalling software:
# echo 0 > /proc/sys/vm/overcommit_memory
Message 15 of 15
(3,421 Views)
