NI Linux Real-Time Discussions
g++: Command not Found
I am trying to install mosquitto broker on a cRIO-9030.
If I use the command opkg install mosquitto, I get a response saying Couldn't find anythign to satisfy mosquitto.
So I switched to trying to compile mosquitto from mosquitto-1.5.8.tar.gz. I can also install it from git source code repository, but both should work.
I am building the tar.gz file on a virtual machine Ubuntu 18.01.1 LTS.
When I run
make WITH_UUID=no WITH_websockets=yes WITH=TLS=no
in the mosquitto directory, I get an error g++: command not found.
I installed oecore-x86_64-core2-64-toolchain-5.0.sh to the directory above mosquitto, but that didn't fix the issue.
which gcc responds with /usr/bin/gcc
but i get nothing back when i run which g++.
I think i can cross compile this from windows using eclipse c/c++, but this method should work too.
Message 1 of 14
(10,644 Views)
Briefly looking over the Mosquito's Makefiles (e.g. https://github.com/eclipse/mosquitto/blob/master/lib/Makefile#L92), it seems like you need to define CROSS_COMPILE to something like /path/to/sysroots/x86_64-nilrtsdk-linux/usr/bin/x86_64-nilrt-linux/x86_64-nilrt-linux- .
Message 2 of 14
(10,636 Views)
Thanks. That worked but now I get an error saying
mosquittopp.cpp:17:19: fatal error: cstdlib: No such file or directory
 #include <cstdlib>
Message 3 of 14
(10,614 Views)
The toolchain you installed provides headers for common libraries like glibc at /path/to/sysroots/x86_64-nilrt-linux/usr/include/ . You'll need to pass some arguments to cc/gcc/g++/etc to add this directory to the search path. Consult gcc documentation for exact flags to use. You should be able to pass these options to Mosquito by setting the LIB_CFLAGS variable.
Message 4 of 14
(10,612 Views)
Thanks for the quick response.
The only thing in /path/to/sysroots/x86_64-nilrt-linux/usr/include/ is a python2.7 folder which wouldn't contain the c++ folder. However I did find c++ headers in /path/to/sysroots/core2-64-nilrt-linux/usr/include/c++/4.9.2/. But that didn't work. I am not 100% sure I set up my make command correctly.
In the documentation I had a hard time telling the difference between what the command should be in the make file (which I don't want to edit), in the c++ code, or if it is in the make command.
So my make command was
make [WITH_UUID.... all the stuff I wrote above] -I  /path/to/sysroots/core2-64-nilrt-linux/usr/include/c++/4.9.2/
But I am not confident with this or if I should just point to the include folder and not all the way to c++. It is also possible I'm way off base here too.
I am playing with the syntax to get it correct and I put in make .... LIB_CFLAGS=-I/path/to/sysroots/core2-64-nilrt-linux/usr/include/c++/4.9.2/ I get a new error.
IT says /path/to/sysroots/x86_64-nilrtsdk-linux/usr/bin/x86_64-nilrt-linux/x86_64-nilrt-linux-cc: Command not found
Message 5 of 14
(10,603 Views)
I am making some progress with CC=gcc.
Message 6 of 14
(10,599 Views)
You might consider simply setting --sysroot and --isysroot to /path/to/sysroots/core2-64-nilrt-linux/ . (g)cc and it's ld should figure out the details with those two breadcrumbs, like which set of /usr/include/... subdirs to search for header. That might be easier than constructing compiler and linker search paths yourself. However, I have not tested this and I'm not completely sure it'll work.
Message 7 of 14
(10,595 Views)
I'll have to look into that, but right now how I am constructing it seems to be moving me forward.
My current error says
config.h: No such file or directory
 #include "config.h"
So I am looking into this. I saw somewhere say I should have ran config.mk (which I didn't do) because it throws a lot of errors like
WITH_TLS_PSK:=yes: command not found
But I guess I have to run config.mk now and fix those problems.
Message 8 of 14
(10,593 Views)
Using generated code (config headers, makefiles, etc) is fairly common workflow in many projects. There's no clear standard for doing this. Autotools is one of the more widely used build systems out there. It seems this project rolled their own. In any case, the workflow is fairly ubiquitous and is exactly what you observed.. first run a script (or sometimes multiple scripts) to configure the source then run `make`. I highly recommend reading over build instructions to figure out their configuration process, then modify it as needed for cross compile.
Message 9 of 14
(10,586 Views)
This is the build instructions from the readme.md
I'll take a look at it again and see if I misunderstood something.
Building from source
To build from source the recommended route for end users is to download the archive from http://mosquitto.org/download/.
On Windows and Mac, use cmake to build. On other platforms, just run make to build. For Windows, see also readme-windows.md.
If you are building from the git repository then the documentation will not already be built. Use make binary to skip building the man pages, or install docbook-xsl on Debian/Ubuntu systems.
Build Dependencies
  • c-ares (libc-ares-dev on Debian based systems) - disable with make WITH_SRV=no
  • libuuid (uuid-dev) - disable with make WITH_UUID=no
  • libwebsockets (libwebsockets-dev) - enable with make WITH_WEBSOCKETS=yes
  • openssl (libssl-dev on Debian based systems) - disable with make WITH_TLS=no
  • xsltproc (xsltproc and docbook-xsl on Debian based systems) - only needed when building from git sources - disable with make WITH_DOCS=no
Message 10 of 14
(10,580 Views)
