NI Linux Real-Time Discussions
g++: Command not Found
Hi ,
g++ does not exist with that name on ni linux rt target. You should first install it with opkg install g++. And then export alias variables.
For a 64 bit target (exemple PXI88xx) you could define the following variables in environment
export CC = x86_64-nilrt-linux-gcc
export CXX = x86_64-nilrt-linux-g++
Then be sure to use that variables in your makefile (which is very common).
Regards
Message 11 of 14
(2,067 Views)
Were you ever able to get this cross compiled and working on the cRIO?
Message 12 of 14
(1,994 Views)
I was able to get Mosquitto installed with TLS with the following combination of things (I might have left something out):
opkg install g++
opkg install packagegroup-core-buildessential
opkg install packagegroup-core-buildessential-dev
opkg install packagegroup-core-python
opkg install packagegroup-core-full-cmdline
opkg install packagegroup-core-perl
export CC=x86_64-nilrt-linux-gcc
export CXX=x86_64-nilrt-linux-g++
wget https://mosquitto.org/files/source/mosquitto-1.6.12.tar.gz
tar xvf mosquitto-1.6.12.tar.gz
cd mosquitto-1.6.12
make LIB_CFLAGS="-I/usr/include/ -fPIC"
make install
then I made an init.d script for mosquitto and installed per the instructions here:
#!/bin/bash
NAME="Mosquitto Startup Script"
DAEMON="/usr/local/sbin/mosquitto"
ARGS=""
USER=mosquitto
PIDFILE=/var/run/mosquitto.pid
do_start() {
        /sbin/start-stop-daemon --start --pidfile $PIDFILE \
                --make-pidfile --background \
                --chuid $USER --exec $DAEMON $ARGS
do_stop() {
    /sbin/start-stop-daemon --stop --pidfile $PIDFILE --verbose
case "$1" in
  start)
    echo "Starting $NAME"
    do_start
  stop)
    echo "Stopping $NAME"
    do_stop
  restart)
    echo "Restarting $NAME"
    do_stop
    do_start
    echo "Usage: $0 {start|stop|restart}"
    exit 1
esac
exit 0
So far everything seems to be working. I'll update if I find that I've left something out.
Message 13 of 14
(1,975 Views)
I've encountered some issues regarding logging and persistence locations. It seems to be related to folder/file permissions and I haven't had a chance to sort through all of that.
Message 14 of 14
(1,866 Views)
