There are situations packages may have conflicts with each other. If we can specify the conflicted packages in the package build spec, It will be very helpful.
This is an existing feature on JKI's VI Package Manager. It uninstalls conflicted package with the new install.
Changing to Completed because as mentioned the NI Package Manager control file supports the conflicts attribute, see Control File Attributes in the NIPM Manual, and more importantly, NI Package Builder 20.0 added support for configuring conflict relationships in solution built packages against dependencies added to the package.
