I recently ran into a problem where packages I created and distributed to my team failed to install because the packages were not compatible with the version of NI Package Manager installed on their system. I usually keep my NI Package Manager instance updated, but other users only use it every so often and may not follow the same practice.
I propose a new feature in NI Package Builder (other NIPM-related tools like LabVIEW Package builder) that allows the package developer to specify a compatible version in the package build spec.
Related to the issue described here: Solved: CompatabilityVersion in control file - NI Community
