NI Package Manager (NIPM)
Error while installing NI-DAQmx
I am trying to install NI-DAQmx with no success.
I have tried installing NI-DAQmx through the NI Package Manager version 21.3.
It throws the following error message before finishing:
We encountered a problem:
An error occurred while installing a package: ni-ede (21.3.0.49275-0+f123)
Additional error information:
An error occurred while installing the MSI at 'niedei64.msi'.
I have attached logs in C:\Users\<Username>\AppData\Local\National Instruments\NI Package Manager\Logs
The machine where I am trying to install NI-DAQmx is a Windows 10 Enterprise LTSC.
Can you help me?
Thank you
(2,350 Views)
The "NIPkgWinInst_ni-ede_20220406T163824.log" file has the following:
DIFXAPP: INFO: Installing devices with Id "ROOT\{F99C2B4A-9E59-47E0-A347-8E8FA89B0458}\NI_ENET_DEV_ENUM" using INF "C:\Windows\System32\DriverStore\FileRepository\niede.inf_amd64_4134ac5968386993\niede.inf".
DIFXAPP: INFO: ENTER UpdateDriverForPlugAndPlayDevices...
DIFXAPP: ERROR: RETURN UpdateDriverForPlugAndPlayDevices. (Error code 0xE0000248: The installation of this device is forbidden by system policy. Contact your system administrator.)
DIFXAPP: ERROR: Installation failed. (Error code 0xE0000248: The installation of this device is forbidden by system policy. Contact your system administrator.)
Is your system managed by IT? If so, they might have a system policy that is preventing the installation and you will need to talk to IT.
Scott Richardson
https://testeract.com
(2,326 Views)
Thanks for the reply.
Is there a way to install NI-DAQmx drivers manually?
(2,301 Views)
I am not aware of any manual way of installing.
Scott Richardson
(2,253 Views)
