NI Package Manager (NIPM)
Prevent package install/uninstall from requiring reboot
I created an nipkg file to handle installing an executable and running some custom pre/post-install actions (i'm registering it as a service via nssm). Any time I install or uninstall the package, it prompts to reboot. Nothing about what I am doing should require a reboot. Is there something I can do to convince NI Package Manager that a reboot is not necessary?
Extra wrinkle: the main point of using an NI Package at all is that our company also leverages Systemlink for remote systems management. I created a package so I could easily deploy it out to remote systems. But I don't want to force those remote systems to reboot any time I want to update this package. So whatever solution would also need to work in the context of remote installation via the Systemlink Client.
The systemlink web UI gave me the option to deselect "reboot if necessary", but that apparently is not sufficient. It prevents the reboot, but it doesn't actually fully install the package. In my case, my package should just copy an exe into Program Files and then run a post-install.bat script; but when it runs the install, the executable file is given some arbitrary GUID name. (I believe this is relying on the Windows PendingFileRenameOperations registry key; on reboot, the file will be renamed back to the original exe name....but again, I don't want to have to do that!)
Is it possible to prevent reboot (and also the PendingFileRenameOperations stuff) on package install/uninstall? Is there some setting in the package build specification itself that I should be setting?
(2,545 Views)
Phil, reboot is required if a file is locked and in use at install time. I think this is happening because the executable is running as a service at the time of install. To mitigate this, the installer would need to be able to shut down the service before installing the executable, and if supported, this could be possible using a pre-install custom execute for the package that installs the executable.
Scott Richardson
https://testeract.com
(2,517 Views)
I have run into the same issue, but it was because I had left open the application as I did the update in NIPM. As long as the app was closed, NIPM would upgrade fine and not request a reboot.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,481 Views)
