NI Package Manager (NIPM)
Error while installing: "ni-ssp-notifier ( 19.0.0.49152-0+f0 )"
Hello guys,
I hope your doing well with LabVIEW. Since I am just a new beginner, I have a problem while installing LabVIEW. So, the error is: "ni-ssp-notifier ( 19.0.0.49152-0+f0 )". Can anyone help me with this error ?
I will really appreciate your help.
Thanks in advance.
Message 1 of 8
(13,588 Views)
Hi Filip,
This error can occur when the user who is running Package Manager does not have permission to access the %temp% folder. Can you please check the folder permissions for the %temp% folder and let us know if the user has appropriate permissions to read/write from/to it?
Message 2 of 8
(13,548 Views)
Can you tell me how can I check the folder permissions for the %temp% folder ??
Message 3 of 8
(13,295 Views)
Open Windows Run and type %localappdata% and hit 'OK'. In the file explorer window that opens, right click on Temp folder and select 'Properties'. Click on the 'Security' tab and check if the user/group that is running NI Package Manager is given full control to access/modify data in that Temp folder.
Message 4 of 8
(13,288 Views)
We have created a KB with a fix for this issue. Posting the link to the KB here in case anyone else runs into this issue later:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DkJeCAK&l=en-US
Message 6 of 8
(13,146 Views)
Edit: I didn't see that the previous post already links to this KB: NI Package Manager Log Indicates Problem Reading Instructions File
Message 7 of 8
(13,145 Views)
Hi, I have checked my Timo folder also and was accessing full access and have also made it resert, but still I get same error message.
Message 8 of 8
(10,208 Views)
