NI Package Manager (NIPM)
I can't find NIMP when it clearly says that it's already installed.
nothing appears when i try. the reason why i bought up MAX earlier was because i found it in the (x86) folder.
Message 11 of 16
(1,699 Views)
If all of those directories show up, but there is no NI software is actually installed, it looks like someone has improperly removed it in the past and you are fighting a bunch of wrong registry keys....
Message 12 of 16
(1,695 Views)
okey. do you think that there is a way to fix it with maybe the use of backup recovery, or?
Message 13 of 16
(1,693 Views)
If the available backup consist of a properly working installation (before all NI PackageManager attempts) --> probably
Message 14 of 16
(1,691 Views)
never mind. i don't think i have a working installation file
Message 15 of 16
(1,689 Views)
Accepted by topic author Mvlfk
Let's try removing and reinstalling NIPM on your machine. Please try the following:
1. From a working machine with NIPM 20.6 installed, zip up the contents of "Program Files/National Instruments/NI Package Manager".
2. Extract those files into a folder on the desktop of the machine with the bad installation of NIPM.
3. Open an admin command prompt window to that folder.
4. Run "NIPackageManager.exe remove ni-package-manager --force-locked --force-essential".
5. Download and run the NIPM installer from here: https://www.ni.com/en-us/support/downloads/software-products/download.package-manager.html#322516.
Message 16 of 16
(1,639 Views)
