NI Package Manager (NIPM)
List packages in a specific feed
I'm wondering if there is a way over CLI to get a List of all packages provided of a registered feed.
I'm looking for something like the commands "list" or "list-installed" but with an additional filter option to select only packages available in the specified feed.
e.g.
nipkg.exe list ni-daqmx-released
...<return>
manitu-daqmx-advanced 0.0.1-23
.. For sure, I could use the "list" or "list-installed" commands and then call the "list-source-feed" command on every package, but this approach is very slow.
Kind regards,
Andreas
(2,813 Views)
There is not a nice way to do this in the CLI. However there is a way to do this in the LabVIEW NIPM API that is available.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,785 Views)
Thank you for your input.
I think parsing the "Packages.stamps" is only possible if the feed is on your local system or some sort of network drive. E.g. I think it is not possible for the ni feeds.
Kind regards,
Andreas
(2,778 Views)
If you know the URL for the NI feed after you install the software, you should be able to directly access the Packages and Packages.stamps files for that feed.
For example:
https://download.ni.com/support/nipkg/products/ni-t/ni-teststand-2020/20.0/released/Packages
https://download.ni.com/support/nipkg/products/ni-t/ni-teststand-2020/20.0/released/Packages.stamps
Scott Richardson
https://testeract.com
(2,704 Views)
