NI Package Manager (NIPM)
NI Package Manager Installation Error - DotnetClientPackageManagerNotInstalledError
Hello All,
while trying to install NIPM, I encountered this error "DotnetClientPackageManagerNotInstalledError".
I have tried to install different Dot Net packages but could not get the NIPM to install.
Does anyone have an idea what could be the problem?
System = Windows 10 Pro
Type = x64
Message 1 of 9
(7,645 Views)
Which installer are you trying to run? Can you provide a link?
Also, can you provide the specific build of Windows 10 that you are using? I'm specifically interested in the 4-digit number. You can get this by opening up a command prompt and entering "winver.exe".
Brandon Grey
Certified LabVIEW Architect
Message 2 of 9
(7,601 Views)
Hello GreyGrey,
I tried the following packages
1. NIPackageManager18.0.2.exe
2. NIPackageManager19.0.exe -
I don't have the links now. I will check my browser history later and paste the links on the post.
The win version is 1803, see attachment.
Regards
iWin
Message 3 of 9
(7,593 Views)
I also have Windows 10 1803 installed and I was able to run the exe downloaded from this link. Make sure that 19.0 and 64-bit are selected before downloading. Give that one a try and let me know if you run into the same error.
Brandon Grey
Message 4 of 9
(7,587 Views)
Hello Grey Grey,
I used your Link again which I have already used before opening this thread but I still get the same Error message.
iWin
Message 5 of 9
(7,581 Views)
Can you share what versions of the .NET Framework you have installed? I created the screenshot below by going to "Add or remove programs" and searching for ".net framework":
Message 6 of 9
(7,569 Views)
Here is the screenshot
Message 7 of 9
(7,546 Views)
I tried installing the same version of the .NET framework as you but can't seem to reproduce the behavior that you are seeing. Have you tried installing to other machines? Is this just machine specific or does it reproduce on multiple machines? Do you know if you have any special (or non-special) anti-virus or other security software that could be stopping items from executing?
It's probably worth getting in contact with support to troubleshoot this further as more complex troubleshooting tasks may be necessary to get to the bottom of this.
Brandon Grey
Message 8 of 9
(7,529 Views)
I didn't try on other machines. I don't know of any special security software that stops it from executing.
I will get in touch with NI support and my IT dept. to see what they can come up with.
Message 9 of 9
(7,526 Views)
