NI Package Manager (NIPM)
The Package Manager cannot find NI-RFSG
dear all,
we just upgraded from LV17 to LV18 and our good old NI-RFSG 17 must be update too. I was trying the usual way from the Package manager but when I search for RFSG I get the reply "No matches found".
I had the RFSG17 installed via the package manager, so I don't understand why the 18 shouldn't work.
Meanwhile I'm downloading the 18 manually...
Thanks for helping me out with this issue,
cheers,
(4,080 Views)
Accepted by hilbert00
NI-RFSG is not downloadable via NI Package Manager yet. However, if you run a product installer and install NI Software on your machine, NI Package Manager will detect that the software is installed, display it as installed, and allow you to uninstall it from inside NI Package Manager. Most likely what happened is that you downloaded and installed NI-RFSG 17.0 using an installer similar to the one that you are downloading for 18.0, and then interacted with it through NIPM.
Currently, not all NI software is available in NI Package Manager, but we are making progress towards meeting that goal.
Brandon Grey
Certified LabVIEW Architect
(4,058 Views)
Thanks 🙂 Good to know...
Anyhow I have now installed the version 18 and I am back to business!
(4,053 Views)
