NI Package Manager (NIPM)
nipkg Documentation Improvements for Command Line
Hi there,
I love the power of NI Package Manager based on my limited experimentation thus far. I'm working to move our TestStand deployment methods to leverage NIPM.
However... Can someone please put the manual on a web page?
I know that this link exists, but it just tells me to refer to the help command. (Which is pretty darned good, by the way... but not perfect.)
Here's what brought me to ask for this today:
I was trying to filter on a package using the info-installed option.
c:\Program Files\National Instruments\NI Package Manager>nipkg help info-installed
info-installed - Show attributes for installed packages
nipkg info-installed [OPTIONS]... [GLOB]
   Show attributes for installed packages.
   [GLOB] - A regular expression used to match against the name of the package.
            If not specified, it will return all possible matches.
OPTIONS
   --suppress-incompatibility-errors
      Suppress forward incompatibility errors.
      WARNING: Suppressing errors could leave your system in an unusable state.
GLOBAL OPTIONS
   --config=[PATH],-c=[PATH]
      Allows the caller to specify an absolute path to a custom configuration file.
ALIASES
   info_installed
Okay great - I'll just use a regex to find my package containing the word "foo":
c:\Program Files\National Instruments\NI Package Manager>nipkg info-installed foo
Bummer. Okay, it's looking for a real regular expression.
c:\Program Files\National Instruments\NI Package Manager>nipkg info-installed .+foo.+
Ahh, it must need quotes:
c:\Program Files\National Instruments\NI Package Manager>nipkg info-installed ".+foo.+"
Maybe I'm overthinking this:
c:\Program Files\National Instruments\NI Package Manager>nipkg info-installed "foo"
Oh, wait - maybe they mean a gimpy "regular expression"
c:\Program Files\National Instruments\NI Package Manager>nipkg info-installed *foo*
Architecture: windows_all
CompatibilityVersion: 190506
Description: foo test system components
  Use this package to install foo components on a new test system.
Filename: \\?\C:\Temp\output/foo-lv17-ts17-new-station-setup_1.0.0_windows_all.nipkg
MD5sum: 6e1dc35410f0ccf4ccb2241a4f5bc945
Maintainer: Mr. Jim <noway@imgonnapostit.com>
Package: foo-lv17-ts17-new-station-setup
Plugin: file
Provides: foo-lv17-ts17-new-station-setup (= 1.0.0)
SourceFeed: file://
Version: 1.0.0
This is a case when a short example would have been really helpful, which is why I'm asking for that sort of thing online?
(Okay, I've completely beat this one to death.)
Thanks for this great product, though!
Mr. Jim
(3,548 Views)
Correct me if I'm wrong, but nipkg is not really supporting regular expressions but rather Windows-like pattern matching, namely "*" and "?".
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,674 Views)
FWIW, a develop mentioned that we perform command-line matching using an implementation of fnmatch that likely supports the same syntax as this python module. A little more powerful than Windows console pattern matching, however definitely not a full regex. We will look at updating documentation in the future. Thanks!
Scott Richardson
https://testeract.com
(2,646 Views)
