2 | |
2 | |
1 | |
1 | |
1 |
When LV throws an error, it's all very easy to catch via callback and/or is auto propigated through the system to Runstate.SequenceError etc.so it can be detected.
When LV throws a warning... the data doesn't seem to go much of anywhere in TS... and unlike LV it doesn't propigate from step to step either.
I'd like to catch and log these warnings in my error handlers (naturally with different logic, but I don't want to lose the data either, it's important sometimes!)
from poking around, it looks like my options are:
(1) creating a custom steptype wrapper around all LabVIEW step calls,
(2) editing each VI called by TS manually
(3) some fun expression(s) in the 'add additional result' or 'post expressions' sectionsof each LV step, to create new variables in TS on the fly... (or using a post-step callback to do the same)
It would be nice if the LV adapter / LV steptypes had some native way of catching this 'almost error' behavior and getting it into the report at least. I don't know if leaning on the error callback is the right answer, since, afterall, these aren't errors... but having a warning callback feels too LV specific...
How about a checkbox in the LV adapter, where you could specify 'treat warnings like errors' and then in the Error callback you could check to see if the bool was false, and punt as desired?
Is there something I'm not seeing that would be a better solution?
--Elaine R.
