Now, when error happens (not during the execution but during the parsing) TS sequence editor displays message like below.
This message can be very meaningless and misleading as it doesn't indicate what is really wrong, it doesn't lead to any file.
It is very difficult to track, because it can happen that after switching the to the development mode this step can be perfectly fine.
Request: please do better description and explanation why particular VIs doesn't work with the RTE.
https://www.ni.com/docs/en-US/bundle/teststand/page/error-reporting-for-broken-vis-in-the-labview.ht...
