 manu.NET
			 on
		01-30-2014
		04:07 AM
			3 Comments (3 New)
			manu.NET
			 on
		01-30-2014
		04:07 AM
			3 Comments (3 New)
It would be nice to be abble to define the report file name "using tags".
For the moment the Report name is created automatically. You can't easily change the order of the filed you want to see in the filename.
You can only modify the date/time position.
I would like to see something like this :
Reportname = [%T<YYYY_mm_DD HH_MM_SS>]_[TestSocket]_[UUT].txt
Thanks.
PS : I am using TestStand 2012 ... perhaps this already exists in TS 2013 ?
Manu.
