Hope it will be good to have AddArrayElements in TestStand (OperatorslFunctions) which will reduce effort using Loops to do the same function.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
