NI TestStand Idea Exchange
Joe_H1
Result Recording Option: Disable in Sequence Call
Status: Already Implemented
Joe, if there's something i'm missing here reach out.
Trent W.
I would like a new option in the Step Properties -> Run Options -> Results Recording Option.  The new option would appear for Sequence Call steps only and would allow the step to disable results recording for all steps in the sequence being called.  I would like this to recursive and apply even to subsequences within the sequence being called.Disable Recording of Steps in Sequence Call.jpg
3 Comments
coldy_robsten
The behavior you're describing is already implemented when setting the result recording option to "Disabled".
WireWeaver
NI Employee (retired)
Status changed to: Already Implemented
Trent W.
Tom117
In which TestStand version was that implemented ?
TestStand 2014 SP1 does not have that behavior.
Also not implemented in TestStand 2019.
Result recording is not disable in the context of the subsequence.
The results of the sub-sequence may not be in the report, but they will still pill up in memory, as long as the subsequence runs.
