NI TestStand Idea Exchange
MimiKLM
Add shortcut key to File-->Unload All modules
Status: Duplicate
Closing this as a duplicate of this idea
Exactly as in subject: add shortcut key to File-->Unload All modules.
It is very annoying to go again and again through File-->Unload All after each iteration of the module development.
2 Comments
MimiKLM
Active Participant
Although, that I've found the same topic posted in the past ( http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Shortcut-to-Unload-All-modules/idc-p/2531552#M757 ) I still believe my proposal is relevant.
Doug has shoved (in the post to the topic with the link above) that developer can customise it. Great!
However, I think that the Unload All button is so heaveli used that the shortcut shall be global and set by default.
HarshaBhushan
Status changed to: Duplicate
