NI TestStand Idea Exchange
asbo
Allow the grouping of sequences within a sequence file
In order to logically sort sequences within a sequence file, you have to add either a prefix to your sequence names or add dummy sequences between sequence groups:
What would be great is if I could could add sequence groups which let me organize my sequences logically in a tree view. Unfortunately, I can't shoop my vision of that at the moment.
5 Comments
RayFarmer
Trusted Enthusiast
I had posted something similar but for  grouping variables.
Regards
Ray Farmer
mavimi
Just to illustrate the idea, as I see it:
coldy_robsten
That would be a similar feature like "Virtual Folders" in LabVIEW projects.
Maybe also allow the addition of (titled) separators, similar as in favorite menus of web browsers...
bienieck
Active Participant
I've seen "dummy sequences" soooo many times. Virtual folders (with ability to nest them) would be great. I think most (if not all) of TS user would give kudo to this idea, but unfortunately not all of them visit this part of the internet...
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
HarshaBhushan
Status changed to: Under Consideration
