NI TestStand Idea Exchange
Stryker_Software_Engineer
Step Types for NI-DAQmx
NI has gone through a lot work to get the IVI Components integrated within TestStand as step types. I was wondering why NI has not incorporated the NI-DAQmx technology into TestStand as step types. I realize most TestStand developers would just create TestStand Adapters in the sequence step written in CVI or LV to interface to NI-DAQmx functions. Even the more advanced TestStand Developers would create their own custom step types to interface to NIDAQmx. I have just done that to where I have created a framework of custom DAQmx step types that I use as a small subset from all the NIDAQmx functions used from the NI-DAQmx library.
8 Comments
Laurent_B
Indeed, that is exactly what I'm looking for. And I didn't find anything good
Laurent
acovian
I definatly agree with this. I would like to not have to create a  labview module for simple daqmx reads.
crossrulz
Knight of NI
acovian, If you like the idea give it a kudos.  Kudos is the measuring stick for how much desire for a feature there is in the community.
GCentral
chiraldude
 I am building a new TestStand driven test system and one thing I need to do is have the sequence halt if there is an e-stop condition.  I can make each code module read the state from daqmx but it would be nice to just read the e-stop state as part of the sequence state and set an error condition that sends execution flow to the Cleanup section.
ecande
+Kudo!
Jean-Louis
Is this what you are looking for : DAQmx Custom Step Types for NI TestsTand ?
They are we easy to use :
And it's FREE !
Kind regards,
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
HarshaBhushan
Please check out DAQmx Steps
HarshaBhushan
Status changed to: Under Consideration
