NI TestStand Idea Exchange
marimuthu
Extract sequence from the selected steps
Status: Already Implemented
As crossrulz pointed out, this feature is present in TestStand 2016 and later:
Creating a Subsequence from Selected Steps
-Trent
It will be good if a "Extract" sequence option present: When we select more than one steps in a sequence, show this option. Once you select extract option, new sequence should be created within the .seq file, and automatically insert a step "Sequence Call" which calls the new sequence.
2 Comments
crossrulz
Knight of NI
Sounds like a duplicate: Tool to create Sequence from Highlighted Steps. And that one is already marked as Complete.
EDIT: Just went looking in TestStand 2016 and there is a "New Subsequence from Steps" right-click option in there.
WireWeaver
NI Employee (retired)
Status changed to: Already Implemented
-Trent
